Black Hole - Benchmark (OLD Version)
Status
Not open for further replies.
I was just pointing it out to you. :P Denther actually spotted it and told me.
Anyway, here is what I got with the 2500K @ 4.3GHz. Obviously my CPU isn't running at 1.6GHz, it's just SpeedStep has kicked in. :/ I sent the score off, I said it was running at 4300MHz.
I just noticed too Smile you also need to lock the form border. :P
SHIT ;P
Nice scores, and darren, I got a life, and I got not that much time to do all this...
Thanks for sending it in!
Will update that soon too.
Nice^^
What's your score at stock? So we can see how much improvement you got?
Don't submit it if you would test on stock. Your internal ip is unique, so it will save the scores you submit and overwrite the ones in the database.
Could you try out your i7 3770k at something like 4.5-4.7ghz?
Idk, but last time you scored less in higher ocs for some odd reason. (Maybe stability, thermal throttle,...)
Very nice score. If you're looking to increase it even more (w/o higher clock), try lowering your latency and increasing the speed of your ram.
Nice scores. But weird is why is your multithreaded that low? Or is spirits multithreaded just uber high?!
Where you running any other programs whilst benching?
Status
