If you are not gaming, why do you need a new card? It will make no difference to every day use and it will most likely be worse in any CAD tasks/GPU simulations due to a lack of CUDA cores on the AMD card.
There is difference.
7750 draws 55W while 9800gt green draws 75W.
This also means that 7750 will be cooler.
7750 can give more fps in games than 9800gt green(I m gaming but not much)
There is also another one reason, I suspect 9800 reached to its end, but lets dont discuss it now).
Can u explain me this phrase "
it will most likely be worse in any CAD tasks/GPU simulations due to a lack of CUDA cores on the AMD card"
Half VRAM is half of the video memory available to the GPU. generally speaking, less memory will mean you will not be able to handle such detailed textures ir such high resolutions when doing GPU intensive tasks.
Both cards have memory 1GB.
But 9800 has DDR3(which I heard is lame) and 7750 DDR5.
The difference is less performance than a reference card and awful cooling. You are better off with an active heatsink than passive, as the sound difference is negligible, yet you get more performance and better cooling
Explain me, why there is less performance? Less performance compare to the active 7750?
Because of -100Mhz clock as Okedokey said?
Awful cooling? I think u r not experienced in passive cooling. All of my cards and cpus are passive in the last years. 9800gt green wears an
arctic cooling accelero heatsink, which look like the one of that 7750. And what temp u think I have? 200oC?
The sound difference is like this--> I hear nothing from the whole pc
