Which one of those programs u want me to run?
So if you come here looking for help to remove malware on your system, we would appreciate it if you would go ahead and follow steps 1-4 outlined below and we will determine if any more scans are needed to get you cleaned up.
:OTL
O3 - HKLM\..\Toolbar: (no name) - Locked - No CLSID value found.
O3 - HKCU\..\Toolbar\WebBrowser: (no name) - {2318C2B1-4965-11D4-9B18-009027A5CD4F} - No CLSID value found.
O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Infodelivery present
O6 - HKLM\Software\Policies\Microsoft\Internet Explorer\Restrictions present
O21:64bit: - SSODL: WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED} - No CLSID value found.
O21 - SSODL: WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED} - No CLSID value found.
@Alternate Data Stream - 169 bytes -> C:\ProgramData\TEMP:B3D74A13
@Alternate Data Stream - 131 bytes -> C:\ProgramData\TEMP:07F6D9E4
Meanwhile I got rid of ****** with SpyHunter program.
Why u asked me those 4 logs since u didnt answer about?
I deleted them because obviously u dont need them.
U want the add/remove list, that means that u r gonna call 'harmfull' even commercial programs, right?
If I run sfc /scannow, it says me that there are corrupted win files. This means I have to make repair?
The OTL log showed software installed that shouldn't be. You have more than 1 antivirus program installed and you shouldn't. If you have corrupt system files then you need to do either a repair which normally doesn't fix this or a full complete fresh install.
Are you actually looking for help? If you don't trust us then I suggest you take a look at the computer security section, it has tons of people coming here for virus and got helped 99% by John successfully (and what would you ask for help if you don't trust us?).
Why u had to wait so much time before answer about my OLT log?
U cant say that useful commercial software 'shouldnt be'.
I had more than 1 antivirus the time I was trying solve a problem. I now have only NIS.
Why normally doesnt fix it?
NIS is Norton. The best suite, according many labs.
Do u really believe that commercial software is harmful? People pay money for them and get their systems infected?...
Anyway, I dont want to search for harmful things now. I want to make a repair in my Win 7 Ult 64 SP1.
I m all ears!
I'm not getting you, you want to repair your OS but you don't want to look for what's wrong?
What software are you talking about by the way?
If a warm has destroyed some windows files, I have to repair them, right?
Warm gone but left behind a file corruption. Can this happen?
I dont think I have warms now.
Do I have to follow this for a repair?
That sentence is not clear, what r u talking about?
