If the driver currently installed is working fine then there is no need to update it.
no,it's for my new internet router,I was talking to the guy from comcast yesterday,he told me that I would have to either install the toshiba driver or to get a new card for my laptop in order to get connected to the new router.
The driver that came preinstalled on the laptop will allow you to connect to the router. Not sure exactly what the comcast tech told you but what he said isn't right.
so I don't need to reinstall that?
Are you trying to connect through wireless or an ethernet cable? Were you setup with a static IP address before? Go into your tcp/ip settings for the type of connection and make sure you are obtaining IP and dns addresses automatically.
network connections, right click on the wireless or lan connection and click on properties, click on tcp/ip in the box and click on properties. You still haven't answered if you are trying to connect through wireless or a cable. That would help a lot.
Then why are you trying to update the lan connection when that doesn't have anything to do with it. What happens when you try connecting to the wireless? Are you able to select your network and enter the security key?
Sounds like you need someone there to verify everything is connected properly and your new router is broadcasting your network ID, which should be by default. Disconnect from your current connection and then click on connect to network, you should see a box come up listing all the available wireless networks in your area. If your new router doesn't show up then you have a problem.
