Help needed -> psu overload?
NikonGuy
banned
As you know ive been talking about a new psu because mines only 430 watt. So here is a question. With alll my new parts in my computer is randomly. Shutting down no warning just off.
The only way Ican get it back on is by unplugging, ( not reseting switch, but fully unplug it ) and then it starts. I cannot get it to stay on more than 10 mins if I get it right back on. Is my poor little psu getting overloaded thus shutting off? My cpu, gpu temps are just fine, no problems there. My motherboard is telling me everything is fine.
C4C
Well-Known Member
Not sure what GPU you have but it's very possible. Do you have another PSU you can try out?
C4C
Well-Known Member
Thanks hehe..
Anyways, the 730 only uses 49w at the max (128bit model).. If there's a store nearby that'll allow you to return an opened PSU, I recommend heading down there and snatching one up.
Otherwise, Amazon has a great return policy. It's how I got a processor to flash my BIOS before my 860K went it. + you don't pay return shipping..
beers
Moderator
As above which one? It may just be flaky or failing.
I mined coins for a while with a : A10-6800K, 2 DIMMS, 2x Radeon 6670s and SSD on a CX430 that had zero problems. Those cards have a pretty similar draw as your 730 too.
C4C
Well-Known Member
Newegg has $20 MIR on the CX600.. You'll want a modular PSU though, I'm assuming?
NikonGuy
banned
could be many things, check ram, remove any overclocks, replace cmos battery
I removed the overclock, and have been watching my Temps, it didn't shut off for a whole day after turning overclock off and been watching my temps. Whenever i'm watching the temps it never shuts off, I have the feeling it shuts off when it is over heating. So I canceled the CPU purchase and bought new cooling instead. I hope the new cooling stops the shut offs!
Okedokey
Well-Known Member
I would suggest you simply had an unstable overclock. Leave everything at stock, your computer on for a week and monitor the reliability tab within windows.
Control Panel\System and Security\Action Center\Reliability Monitor
NikonGuy
banned
The computer still shuts off even with 0 overclocking
Okedokey
Well-Known Member
Ok when you say shut off, the computer simply and unexpectedly turned off. No BSOD, no Windows is shutting down or anything like that?
NikonGuy
banned
Nope, Just bam dead. No power surge or any weather that would cause anything to reset, nope, just dead. And I cannot turn it back on without unplugging the PSU for 5 sec then plug it back in. Only then t turns back on.
Okedokey
Well-Known Member
Ok, first thing to do would be to replace the CMOS battery. You haven't replaced the PSU yet have you?
