You have been added.I will join if that's okay? My username is BarredCardinal
Where? The only one I knew of was the one I built in my house.I found a nether portal near spawn. I assume it's okay if I use it?![]()
If you can find it, you can have it
Hah, I filled the basement with TNT and it activated on the interior floor switch for somebody. To be fair, the sign said do not enter...Uhm..... Got on the server to work on my noteblock loop and noticed beers' island is gone...... like somebody used TNT.....
Hah, I filled the basement with TNT and it activated on the interior floor switch for somebody. To be fair, the sign said do not enter...![]()
so THAT is what you were building! I like it... though it's not all in survival
by the way Travis, I searched all of the nether and there are not any nether warts. Is it possible to have it reset?
The nether.What specifically do you want reset?
so THAT is what you were building! I like it... though it's not all in survival![]()
Next one will be Survival. I just wanted a showcase piece close to Spawn for the heck of it.
