Nuetab Air 7 problem.
Grantapus
hello, i just got a Neutab air for about 75 bucks, it was great, but when i plugged it in the charge, the battery level just stays at %58! i have left it for like 20 min, and has not changed!!! i think its because the tablet cant sense the battery changing well enough?
plz help.
beers
Moderator
What is the amperage of the charger rated at?
If 500ma I'd either find a higher amperage charger or turn it off while it's charging.
johnb35
Administrator
Either bad charger or bad charging port. With my daughters phone, only certain chargers will actually charge it.
johnb35
Administrator
Leave it plugged in, not used and you should see a light on it designating its charging. Could also be a bad internal battery.
Grantapus
Hey guys! I left the tab
To charge over night, it worked!! I found out that you have to charge it for along time before you try to charge it fast!
Sent from neutab air7!!
