svchost.exe
way2evil
svchost.exe is getting me aggrivated. i have no idea what it does, yet it runs at 150k memory and spikes my cpu usage to 100. i kill it but it comes back. i read that it could be a trojan or something. what should i do?
I read in a PC World magazine that they're there to help run the programs that are running or something along that line. That's why there are alot of them.
it isn't ever supposed to be taking that much up tho
alright i have something because trend micro anti spyware venus spy trap says something is attempting a url zone change and it lists about 50 porn sites. i ran every spyware scanner available and removed some crap but nothing big
"Svchost.exe" (Generic Host Process for Win32 Services) is an integral part of Windows OS. It cannot be stopped or restarted manually. It manages 32-bit DLLs and other services. At startup, Svchost.exe checks the services portion of the registry to construct a list of services that it needs to load. In normal conditions multiple instances of Svchost.exe run at the same time. Each Svchost.exe session can contain a grouping of services, so that separate services can be run depending on how and where Svchost.exe is started. This allows for better control and debugging.
Note: The svchost.exe file is located in the C:\Windows\System32 folder. In other cases, svchost.exe is a virus, spyware, trojan or worm! If your system scans clean then chances are its just windows going about its business.
Check where the svchost.exe process is coming from by using ProcessXP.. get it here for free: http://www.sysinternals.com/Utilities/ProcessExplorer.html
Post a Hijack This log in the security section.
i figured out it was lexmark proceses running. they get the svchost all worked up and kill resources. i read up and lexmark lexpps.exe and lex something else .exe cannot be killed and if they are the printer wont spool. well, i figured it out. go to run services.msc and look for lexbce and disable it. then start the print spool service again if it stopped. if anyone needs it there it is
well i guess that wasent it. now the error the instruction at 0x00aa96bc referenced memory at 0x00000000 they memory could not be written. and the damn error thing where svchost maxs my resources is still there
i know its soon but if anyone knows anything please tell. i am two seconds from taking this keyboard and breaking it over my knee. this whole comp is gone the day conroe comes out
What program? svchost still?
My fault. I wasn't clear, or maybe I was but I'm not sure about your answer, anyway just to make sure: On the "0x00aa96bc referenced memory at 0x00000000" message box does the title say svchost.exe or some other program?
50% cpu usage
I got a problm. each tiime I load a game of any kind (Dirt 2, Batman, Farcry 2) the game laggs and when i open task manager there a svchost process called Generic Host Process for Win32 Services:confused: and it is using 50% cpu power and if I go to the process it says Power manager WTF....
I need help pls its getting me very irritated.
any info or help will be very app
