Because T1 doesn't have a fast downstream.why not get t1 internet connection? $300/month!
My cable internet (6000/512) rips T1's downstream to shreds.why not get t1 internet connection? $300/month!
Approx: $14,100
- Processor:Intel Core 2 Extreme X6800 2.93GHz / 4MB Cache / 1066MHz FSB / Dual-Core / OEM / Socket 775 / Processor - $1,150
- Motherboard: ASUS P5W DH DELUXE/WIFI-AP Socket T (LGA 775) Intel 975X ATX Intel Motherboard - $270
- RAM: G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 1000 (PC2 8000) Dual Channel Kit System Memory - (get 2 of this pack) $468x2=$936
- Video Card: XFX PVT71UZDF9 Geforce 7950GX2 1GB 512-bit (256-bit x2) GDDR3 PCI Express x16 Xtreme Video Card - $610
- Sound Card: Creative Sound Blaster X-Fi Elite 7.1 Channels 24-bit 96KHz PCI Interface Sound Card - $385
- Drives:
- SCSI Card: LSI Logic LSI00008 PCI Express SCSI RAID storage adapter RAID 0/1/5/10/50 - $630
- C: Seagate Cheetah 15K.4 ST3146854LW 147GB 15,000 RPM 8MB Cache SCSI Ultra320 68pin Hard Drive x2 RAID - $2,200
- D: Western Digital Raptor X WD1500AHFD 150GB 10,000 RPM 16MB Cache Serial ATA150 Hard Drive x3 RAID - $930
- E: Seagate Barracuda 7200.10 ST3750640AS 750GB 7200 RPM 16MB Cache SATA 3.0Gb/s (The First Perpendicular Recording) Hard Drive x3 RAID -$1,200
- F: PLEXTOR Black 16X DVD+R 8X DVD+RW 6X DVD+R DL 16X DVD-R 4X DVD-RW 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM 8M Cache IDE Slot Load 16X DVD±R DVD Burner - $147
- G: PLEXTOR Black 16X DVD+R 8X DVD+RW 6X DVD+R DL 16X DVD-R 4X DVD-RW 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM 8M Cache IDE Slot Load 16X DVD±R DVD Burner - $147
- Case: COOLER MASTER Stacker 830 RC-830-SSN1 Silver Aluminum ATX Full Tower Computer Case - $230
- Power Supply: PC Power & Cooling Turbo-Cool 1KW EPS12V SLI, SSI Power Supply - $500
- Cooling Setup:
- Thermal Paste: Arctic Silver 5 Thermal Compound - $16
- CPU Cooling: ZALMAN RESERATOR 1 Plus Fanless Water Cooling System (Reservoir+Radiator+Water Pump) - $230
- Case Cooling: SILVERSTONE FM121 120mm 2 Ball Case Cooling Fan - get 9 of these $16x9=$144
- Operating System: Windows Vista Beta 2 - Free
- Speakers: Logitech Z-5500 505 Watts 5.1 Speaker - like $300
- Monitor:2 Dell 30" monitors... - Around $4,000
Approx: $14,100
- Drives:
- Cooling Setup:
Ummm...slight problem THe RAM doesn't work with the motherboard.Approx: $14,100
- Drives:
- Cooling Setup:
Approx: $14,100
- Drives:
- Cooling Setup:
1. That is an ATI video card, you can't do SLI with it.The_Beast said:video card in sli $1300 each
http://www.newegg.com/Product/Produc...82E16814195007
Lol, if you wont the lottery, you could have wire management 10 times better.Why not buy a Voodoo PC. I am SERIOUSLY impressed with the wire management in their systems.
That just about does it, I dont know what your going to do with 9 fans.
Ever heard of the story of the 3 little pigs? This saves on all the huffing and puffing that the big bad wolf has to do.That just about does it, I dont know what your going to do with 9 fans.
meh... not even 2 7950GT2X's in SLI?..![]()
Ummm...slight problem THe RAM doesn't work with the motherboard.![]()
