Hmm...Does anyone know a way to get the game to run at 1280x1024? It's not in the video options(same thing with Battlefield 2).
This should be your target path under properties of the icon:
"C:\Battlefield 2142 Beta\" +menu 1 +fullscreen 1 +szx 1280 +szy 1024
While changing between menus and sometimes during game play the darn thing minimizes to the task bar, at which time I maximize it again where it runs again fine, this is frigging annoying but does not happen often during actual game play. So anyway the game runs smooth as pie (loads a bit slow though) which I'm surprised because video that I've seen so far looked so good and I'm playing on an ageing 6800 GT.
I d-loaded my demo from yahoo games, but I'm having trouble with the game loading. It acts like it's loading then it goes to a black screen and an error comes up? Any ideas? I've even updated my direct x and v-card drivers....
 . She does not play games (not PC games anyway).
. She does not play games (not PC games anyway).you need the october release of DX9CAn update... The issue I had with the game minimizing was apparently due to the video drivers I was using. I had started using more updated drivers then most of my games started behaving this way. I installed older drivers and the game runs just fine now.
I'd start by downloading it from another source and trying again. If then it still happens we can see what might be the problem.
Edit:
Actually the games minimizing turned out to be the cause of the F@H software. I'm going to take it off this system and run it from my wifes computer. She does not play games (not PC games anyway).
What does that help? Just curious because the game runs just fine right now.
I dont think that would help, since I have that and I still have that problem. I'm going to try disabled F@H and see if that helps.
.I disabled it and it seems to have worked so far. Im running the GUI version, how about you?
Still couldn't get it to work. It acts like it's going to load then it pops back out to windows and gives an error... Hum.....Any ideas?
