*drum roll* ..... new build (with list of parts!)
great. works. There is no difference between the brands that make the DVD-RWs, just pick anyone.
One comment though, your ram is kinda slow. Get something like PC-5300 at least. (667MHZ).
please dont bump after 1 hours, we dont live here you know :) someone will answer eventially
no for your 'rig'
Case - are you seriously think of spending so much on a case? is this machine for looking at of using? Ditch that over prices metal box, get something cheap and put it towards upgradeing to an e6600, the extra 2mb cache will be better than a pretty box:)
motherboard - as said your choice aint the best :D, dispite the hype the P965 still loses out to the p975x quite a lot on the c2d. Maybe consider something like
http://www.newegg.com/Product/Product.asp?Item=N82E16813136168
or even better
http://www.newegg.com/Product/Product.asp?Item=N82E16813130051
but make sure its revision 2 (the power up version) as v1 had issues
ram = fine
hdd = good choice, but could save a bit on
keyboard = sigh, really... well its your money
mouse = could get same functionality for cheap
do not get the value select 5300 that was suggested by someone
i agre with ^^ , i paid 30 bucks for my ase, came with a 420watt fan and its great..i dont see point in spending all this extra do...what does it really do for you?
hovers over your work space so you save desk room?? :P
no for your 'rig'
or even better
ram = fine
Really, you must be kidding. The Gigabyte GA-965P-DS3 is one of the best motherboards out there for overclocking.
alright
ill look around for a cheaper case, i just wanted something with a good number of bays, good place to put more fans, and space inside to work with
sorry for the bump
ill look around iam going to start purchasing 'some' of the stuff nov.1
i love the keyboard and mouse sorry lol i just have always had my eye on that
EDIT::: so i should get a new mobo?
by all means, get what you want...we are only providing suggestions, but we aren't going to be the bodies in your seat using your pc.
i know, this is just my first time buying computer parts, and i dont want to mess up and i want to assure iam getting compatible stuff
iam having trouble finding a decent case
id like....2 cd/dvd burners, fan contoller/multifunctional panel, and maybe something else that fits inside the 5.25 panels
can i get some ideas for a cheap nice looking case
