Lord Of The Ming
http://www.engadget.com/2007/01/24/pentium-4-overclocked-to-8ghz-lets-see-your-fancy-core-2-try-t/
This is just nuts, probably a world record...
As I've said before, that wasn't really a processor. And it it was only frozen to 'near absolute zero' temperatures as it's impossible to freeze anything to absolute 0.anyone read that article on here last week about the 500ghz room temperature processor created by IBM?
They froze the processor to absolute zero, and apparently it creates some sort of chemical change that allows the processor to handle extremely high temperatures at room temperature.
let's see your fancy Core 2 try that
It is questionable, the highest Core 2 Duo is somewhere around 5Ghz right now. But it would definetely be able to beat it in performance![]()
that's nothing.
Do you know how many pipeline stages a C2D has? 14. The purpose of having a stupidly long pipeline is that you can move through each stage fast enabling you to ramp clock speed through the roof. If it takes 10ns to do the slowest step that determines your clock speed cap.yeah i think a C2D could go way past 8ghz if it had liquid nitrogen and all the other mods that the P4 had
Kinc seems to have found a real monster of a processor as the Core 2 Extreme QX6700 processor he used during the world record session was running at 4.92GHz and was later pushed to over 5.0GHz for a complete 3DMark06 run. To our knowledge it's the first time anyone runs Intel's quad-core processor at over 5.0GHz through an entire 3DMark06 run.
