Build Suggestions -Performance machine
SolApathy
Alright, as you can see from the link in my sig I usually use a gaming laptop. Most of my time is spent in that forum, however at this time I am looking to build a desktop rig & have the build below in mind.
I am very familiar with overclocking (which I plan on doing), cooling solutions...etc... I am not interested in SLi. I have found the performance increase to be too low for the cost, which is why I did not choose a 680 board w/2 16x slots. My only future addition may be a Physics card, once more games support it. I also have an audio card already (Audigy 2 ZS Plat).
any suggestions would be appreciated, as the other forums I have been to have met with responses limited to "nVidia sucks", "don't go Intel, they suck". Obviously those responses offer no help in making a decision.
I will take advice on any part of this build. Currently the cost sits @ $2,050.00. That includes shipping & does not include mail in rebates (I've found half the time you never get them). I did not include my selections for my fans, cathodes...and other junk that is not that important...
SAMSUNG 18X DVD±R DVD Burner With 12X DVD-RAM Write, LightScribe Technology Black SATA Model SH-S183L
Item #: N82E16827151141
Thermaltake Tsunami VA3000BWA Black Aluminum ATX Mid Tower Item #: N82E16811133132
AeroCool PowerPanel-BK Panel - Retail
Item #: N82E16811999155
ZALMAN CNPS9500 LED 92mm 2 Ball Cooling Fan with Heatsink - Retail
Item #: N82E16835118223
Intel Core 2 Duo E6700 Conroe 2.66GHz LGA 775 Processor Model BX80557E6700 - Retail
Item #: N82E16819115002
Patriot eXtreme Performance 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model PDC22G6400LLK
Item #: N82E16820220144 (Timing 4-4-4-12 )
ASUS P5K DELUXE/WIFI-AP LGA 775 Intel P35 ATX Intel Motherboard - Retail
Item #: N82E16813131182
(2) SAMSUNG SpinPoint T Series HD501LJ 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Item #: N82E16822152052
HIPER HPU-4M730-SS EPS12V v2.91 730W Power Supply - Retail
Item #: N82E16817128008
Arctic Silver 5 Thermal Compound - OEM
Item #: N82E16835100007
BFG Tech BFGE88768UOCE GeForce 8800Ultra 768MB GDDR3 PCI Express x16 OC HDCP Video Card - Retail
Item #: N82E16814143107
I appreciate your time.
-Sol
Looks good...does that price account for the 22nds price drops? Or you just can't wait three weeks and need to build now? Only thing I would change is the dvd drive, I'd go with lite-on 20x. But its not that big of a deal. Either way, good luck with the build!
I know the 6750's are coming out w/ the price drops on the 22nd. I am trying to get the build in earlier, as that single price change will not really affect my build all that much.
I would go with the quad core but the performance increase is not even noticable since the 2 additional cores are not even being used at this point (at least with the software I use). Not even Supreme Commander utilizes more than 2 cores at this point.
I chose that particular DVD drive since it has lightscribe & I hate writing on discs by hand lol.
Thanks for the advice!
It'll for the price you're getting the E6700 you could get the Q6600 quad or the E6850 3ghz dual and even save money, i would get the antec 900 rather than the Thermaltake, a lite on dvd burner is better and the price difference isn't that much, get a real psu those hiper sucks other than that is fine
Corsair 620w
http://www.buy.com/prod/corsair-620w-sli-certified-modular-atx-power-supply/q/loc/101/203270718.html
Antec 900
http://shop3.outpost.com/product/4991611?
Lite on burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106072
I think I will getthe Lite-On drive. I am concerned that 620 watt PSU recommended would be cutting too close with my loads, esp with overclocking, & a total of 4 HDD's (2 500 GB/2 160GB (RAID 1) (archive drive))
I was looking into the 680 boards. The reason I did nt go for them
-Was not interested in SLi
-The reviews on this particular board have shown it has an excellent overclocking rputation.
If you have a particular reason I should look more into the 680 boards let me know.
the other boards I have been to have replied with "Intel sucks, go nvidia" "Go intel, nVidia sucks" "ATI is bad" "nvidia is bad"...Unfortunately personal preference and simple statements like that do little to help me in making a decision.
If you're going sli with the geforce 8 series then you'll need more than the corsair or the hiper, something around 850 watts with at least 50 amps
He actually mentionned he had not intentions to SLI. As for the Corsair 620HX, I am quite sure it would be plenty to provide power for all you plan to put in there.
yes as I stated earlier I don't plan on SLi. Initially I was, but after serious consideration (looking at test comparisons) I saw little benefit. the price to performance value just isn't there. that is one of the reasons I chose the P35, instead of the 680 series boards.
I wish there was a definitive way to tell what your power requirements are going to be. I know the 8800 ultra draws 300+ under load, that coupled with an oc'ed e6700( I plan on around 3.4GHz), Oc'ed RAM, 4 Hard Drives, 2 optical drives, an augigy 2 ZS Plat, several 120MM LED fans, 2 cold cathodes, & my G15 keyboard I would be pretty darn close to maxing out a 620 watt PSU.
http://www.extreme.outervision.com/psucalculatorlite.jsp
thanks a lot. with my complete configuration I am showing 587 watts of current draw overclocked. 623 under a TDP of 100% (which is rare)
Well I took the plunge a little earlier. Here is what I ended up with... I just went with a 700 in the event I decide to grab a Physics processor later on when more games support it.
LITE-ON 20X DVD±R DVD Burner with LightScribe Black SATA Model LH-20A1L-06 - Retail
Item #: N82E16827106072
Thermaltake Tsunami VA3000BWA Black Aluminum ATX Mid Tower Computer Case - Retail
MSI NX8800Ultra-T2D768E-HD-OC GeForce 8800Ultra 768MB GDDR3 PCI Express x16 HDCP Video Card - Retail
Clocks: 660/2300
Thermaltake W0106RU Complies with ATX 12V 2.2 & EPS 12V version 700W Power Supply - Retail
Item #: N82E16817153039
Patriot eXtreme Performance 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Timings: 4-4-4-12
LOGISYS Computer CLK12BL2 12" DUAL COLD CATHODE KIT - OEM
Item #: N82E16811994001
ASUS WL-BTD201M USB 2.0 Bluetooth Dongle - Retail
Item #: N82E16833320016
(2) APEVIA CF12SL-UBL 120mm Blue LED Case Fan - Retail
Item #: N82E16811998121
Rosewill RFX-100B 90mm PCI Slot Case Cooler - Retail
Item #: N82E16835200019
ZALMAN 9700 LED 110mm 2 Ball CPU Cooler - Retail
Item #: N82E16835118019
ATM those Phyx cards are useless and is like wasting money i'd rather suggest you to wait till then most likely there will be even better models by then
yeah that is why I did not get one, though I do play COV, which can utilize the card.
i figure once DX10 gets fully adopted Physics will start to play a more important role
-660/2.3GHz clocks vs 575/1.8GHz
-The Ultra was not that much more than the GTX
-I am looking to upgrade my 32" 1360x768 to a 1920x1200 37" so Iwant the best performance I can get in a single card.
-I have the money
