!!!!!!! -- water cooling -- !!!!!!!!!
I must say if you really want to see how water cooling fits and what not... 3DGAMEMAN on youtube covers quite a few water cooling solutions. If you want to have a look I done a quick search on youtube... heres what it came up with... Water Cooling Hope it helps
wow, thanks man, that's really helpful!!
hey, does anybody know what's the actual difference between h20-120 and h20-220? besides the price i mean lol :cool:
Could I ask what is so wrong with fans? Because from the information I have gained from many forums and whatnot there isn't a dramatic difference in temps. Then you take the risks into account, you know leaks and what not and then if theres a missfunctioning link and the tube comes off water over everything(Water+Electricity = Bugger+Replaceing Parts). Then if you put up the price of a water cooling system against 20-30 fans for that price. Personally I'd go for the fans... haha. Also you could proberly get a mean case with tonnes of places to put fans for the amount of cash for a water cooling system. Sorry for being a downer. So you could pretty much call me a fan lover. The other way you could do it is that you could wait for a more reliable water cooling system, like less chance of a leak.
Haha, you are right it looks good, it is new technology, and it is sorta quiet.
But remember new technology isn't always the best, it isn't completely quiet because the radiators still have fans(Most of them) and its always good to skite about your new stuff because I do... But if the shit hits the fan and a leak occurs then your computer friends are going to laugh and say stuff like "Good old watercooling Aye?", But maybe a waterfall inside your case isn't that bad aye? I'd be mean to see
i dunno, i just want it. wanna try.. and plus that new quad-core which i'm about to buy will need a hellova cooling i guess
Yeah I'd love to try it too :p . There was one Watercooling solution that kept the CPU at 0 Degrese . I heard it was Frozen on one side of the radiator and next to boiling on the other side... Or somthing like that, I can't completely remember what component it was but that sounds freggen worth it :P
Heres an idea ask around on this forum and others who has Quad-Core and ask them their temps and cooling solution.
okay, lemme ask ppl around - sounds like a good idea
ps. hey, what's with ur language? (nothing personal)
My language you mean like the words I use?? I don't know maybe its because I'm from New Zealand or somthing, I proberly got it off a friend?
no everything's fine, just prob some typos.. and yea makes sense - new zealand - what's ur first language anyways? like the native one?
sorry for the offtop, mr. moderator, but we have to figure out the means of communication, right? lol
New Zealand's English, it seems different from everyone else's like some of the words are spelt differently then the U.S.A
It could also be my shocking spelling
haha gotcha.. it's all good anyways..
back to the topic tho.
does anyone have a clue about the actual difference between h20-120 and h20-220? i browsed thru their website, but it's so.. meh not-taken-care-of i cudn't figure anything out
SCARRRY!!!!!
do u have to refill a water cooling system every once in a while?? that sounds so unconvenient! y tho?? does it get evaporated or what? i thouhgt it was a closed system
I think you may have to refill the water cooling system once every year, i think. Its pretty easy to do though.
http://www.frozencpu.com/products/2...38_Conversion_Kit_317_GPH.html?tl=g30c107s155
Pump - $90
http://www.frozencpu.com/products/4...ealth_360_Radiator_-_Black.html?tl=g30c95s161
Radiator - $60
http://www.frozencpu.com/products/5...e_Universal_CPU_Waterblock.html?tl=g30c85s141
CPU Block - $55
^^^that is about what you would find in that Swiftech kit on Newegg only it's $50 cheaper and you get a much better rad^^^
http://www.frozencpu.com/products/2...30_SLI_Chipset_Water_Block.html?tl=g30c89s149
Chipset - $30
http://www.frozencpu.com/products/2...Block_w_MC14_BGA_Ramsinks_.html?tl=g30c87s145
GPU Block - $60
the only other things you need is a T line, tubing, and some clamps
pump->T line->rad->CPU->GPU->Chipset->pump->
how many t-lines, tubing and clamps? a handful? lol
seriously, how do u buy them? i believe that u can cut tubes to get the right lengths, but clamps and stuff - there must be the exact #, right?
man!! u r tha man, man!! that's some mega-comprehensive reply!! appreciate. :)
thanks for the complement
you only need 1 T line, a few feet tubing and some clamps
http://www.frozencpu.com/products/2269/ex-tub-116/Danger_Den_G_14_High_Flow_Thread_Barb_-_12_ID.html
you will need 2 of these for the rad
http://www.frozencpu.com/products/5...for_12_OD_to_58_OD_Tubing.html?tl=g30c101s180
and 2 of these for the pump
http://www.frozencpu.com/products/2195/ex-res-45/Danger_Den_Fillport_-_Black.html?tl=g30c101s460
you might want a fill port too
I know what I put together is a little over budget but you get soo much more than the kit
lol, didn't you say something to me about control and kit being more expensive? jus messing with you
