lynxthechosen0
Is this processor any good ?
The latest and highest performing desktop line would be the Core 2 Duo/Quad.maybe I'm a bit behind the times then...oh well. What's the latest top of the line processor then?
I got it, love it. Overclocks well but Core 2 Duos OC better. At stock speeds its comparable to the E6600.
More like around the E6400, 2Mb Cache and the 6000+ is more comparable to the E6600
Have you seen benchmarks? at stock speeds the 6000 beats it in most of them...
If anything at 2.8ghz the 5600 would compare to the E6550
the 6400 is closer to the 5000 or 5200.
Just look at the benchmarks here
http://www.anandtech.com/printarticle.aspx?i=3038
E6550 outperforms 5600+ most of the time
E6550 performs on par with 6000+
E6400 beats 5000+ in most cases
http://www.xbitlabs.com/articles/cpu/display/core2duo-e6420_7.html#sect0
I think is more comparable to 5200+ and E6420 is comparable to 5600+ at stock
I used the word (closer), it beats the 5000 by a few points, big deal. If they used the 5200 and I did say 5000 or 5200 the 5200 would probable be a few points ahead of the 6400. The 6400 is pretty much between the 5000 and the 5200
It all comes down to the Core 2 has about a 400 to 500MHZ advantage on the X2. If you have a Core 2 at 1.8 it takes a X2 at 2.2 to equal it
