Ignorantguy
I just bought a 500gig ext My book and im trying to format it to FAT32 using partition magic 7. For some reason windows xp wont let me format in FAT. So im trying pm7 but it wont let me either. What am i doing wrong?
pc eye, where do you get 55gb and lack of bios support from? what does bios has to do with anything in this context?
that limitation has little to do with bios.
But anyways, this is window xp, not old dos. And if you use a proper 3rd party formatting tool, you can go way beyond the 32 gb-limitation in xp
To answer your question...
Make an 98/95 bootdisk... www.bootdisk.com (I think)
Pop the disk in an boot from it. Type in fdisk. Click on 4 and press enter. Remember the type, go to the deletion part and delete the partition, not make another partition, use max size. Get your OS disk, delete that partition and make an FAT32 or partition.
Hope that helped.
With the drive being an external usb type fdisk won't work from any boot floppy. Ignorantguy's reference to a MyBook external drive means a partitioning tool that works in Windows would be needed. This is another reason why the Disk Management tool or a software like Partition Magix for an NTFS type partition would be far better for the larger drive there. This is why the question of "why Fat32?" was asked from the beginning.
They were called bios bypass utilties in those times before the chipsets allow for the new ATA100 to come seeing larger drives available. 13gb was once a super sized drive about 8yrs. ago. But even with lba there where still some problem due to Fat32 to overcome. The updated fdisk then allowed for a larger partition.
