Buying on Sunday? Double Check, Take a peek
Well, to upgrade I'd have to buy a new mobo, new gpu, ram.....and bam a new pc is already being put together. So, I'm doing just that.
Regardless of the HD you choose, your new rig is gonna be awesome. The RAM is really cool. Have fun! :)
Thanks and yeah, I specically chose that ram cause of the LED's, now the damn Antec 1200 needs to come out so I can see them.
Yeah, they really improved on the cable management stuff w/ the 1200. Short of cutting holes in the back of my 900, there's not much I can do in that area. :(
Don't matter. I'm gettin' the CM Cosmos soon. ;)
What do you guys think of
Aerocool FP-01
Yeah 64 bit vista.
Edit: I wish these boards supported SLI. They do support crossfire though.
£370 for case!!, unless you planning on framing it for all to see Id say thats a lot!
No, I'm keeping it around the 2,000 range.
are you really willing to spend 20% of you budget on a case,
Raid? I would never partition that much space to windows, unless I really like loosing data.
depends on the stiping method, if you have some parity its ok
It's ending about around 2,400. The case also includes the PSU's remember that. Sorry, I don't know that much about raid.
Edit: So it will be more like 15% which is divided between the case and the PSU's. Also it's more of a personal budget than actual budget. I could spend way more if I chose.
hmmm... the PSU is included with the case which might be bad like in most cases...
but seeing that its an Antec build, it might be worth a try
well im not sure how good the 2 psu's they supply are. Would look into that before relying on those PSU's
