Need opinions on spec. Please!
littlenlnga
Chip 189.99
Intel Core 2 Duo E6750 Conroe 2.66GHz LGA 775 Processor Model BX80557E6750 - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
Mother board 94.99
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
Graphic Card 179.00
SAPPHIRE 100216L Radeon HD 3850 256MB 256-bit GDDR3 PCI Express 2.0 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102714
CD/DVD BURNER 28.99
LG Electronics Black LG Super Multi 18x SATA DVD Burner GSA-H62NK, 10x DVD+/-R DL, 6x DVD-RW, 8x DVD+RW, 12x DVD-RAM - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136120
Case Free
RAIDMAX SAGITTA ATX-921WB Black SECC Steel ATX Mid Tower Computer Case - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16811156087
RAM 38.00
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048-6400 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145590
Power 54.99
Thermaltake Purepower W0100RU ATX 12V 2.0 500W Power Supply - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16817153052
hard drive 74.99
Western Digital Caviar RE WD2500YS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136055
Total 750.94
Tax 54.44
Shipping 26.00
Grand total 831.38 (711.39 after rebate)
831.38 for a computer come on now buts its ur money do want u want
that isn't that bad actually (depending on what you want to do with it)...my upcoming build is going to top $1500 and I'm only 16....(gotta get this crap now before I have to start paying bills haha)
damn.i do i little gaming but not too much i got about a 350.00 dollar computer.
2.2 ghz cpu[getting a dual core friday]
2gb ram
120gb hdd
x850 gto2
thats perfect for me
g0rilla z03, You need to chill. I know you have a system worth $350, and that's fine. But a $350 system is a $350 system. If you want to do any serious gaming, or anything decent on a system, the more money you can throw at it the better. You spend as much as you can afford to get the best you can.
While in 3 years a $2000 system is going to only be worth $350, its still about doing the best you can now, and not worry about what you can do in the future.
littlenlnga, that looks like a decent build for the money.
WHY gaming? because i play games
Ignore him.
Chip 189.99
Intel Core 2 Duo E6750 Conroe 2.66GHz LGA 775 Processor Model BX80557E6750 - Retail http://www.newegg.com/Product/Produc...82E16819115017
Mother board 94.99
http://www.newegg.com/Product/Produc...82E16813128059
Graphic Card 179.00
http://www.newegg.com/Product/Produc...82E16814102714
CD/DVD BURNER 28.99
http://www.newegg.com/Product/Produc...82E16827136120
Case Free
RAIDMAX SAGITTA ATX-921WB Black SECC Steel ATX Mid Tower Computer Case - Retail http://www.newegg.com/Product/Produc...82E16811156087
RAM 38.00
http://www.newegg.com/Product/Produc...82E16820145590
Power 54.99
Thermaltake Purepower W0100RU ATX 12V 2.0 500W Power Supply - Retail http://www.newegg.com/Product/Produc...82E16817153052
hard drive 74.99
http://www.newegg.com/Product/Produc...82E16822136055
Look for the Q6600...
And the P31-DS3L... If it's less than 4GB of RAM that is...
And the HD3870, or the 8800GT..
And the OCZ 700W or the Rosewill 550W SLi
From other sites, you could get a WAYYY better deal. Quad core, 4GB....
Newegg or other sites?
This is my most current build. Tell me what you think about it and what to change.
Chip 189.99
Mother board 94.99
Graphic Card 179.00
CD/DVD BURNER 28.99
Case W/ Power Supply 139.99 Rebate 40
Antec Sonata Designer Silver Steel ATX Mid Tower Computer Case 500W Power Supply - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16811129036
RAM 88.00 Rebate 40
hard drive 74.99
Total 864.12
Rebate 80
GRANDTOTAL: 784.1
Chip 189.99
Mother board 94.99
Graphic Card 179.00
CD/DVD BURNER 28.99
RAM 88.00 Rebate 40
hard drive 74.99
Total 864.12
Rebate 80
GRANDTOTAL: 784.1
Everything looks fine to me.
But will you consider change the DVD burner to LITE-ON LH-20A1S retail?
Just because it have Replaceable White Front Panel, which your case's color
well i don't need a 2,000 dollar for wat i do.if i wanted a gaming computer i will throw out 1,500 in an alienware
