PC Cooling / Noise Poll
You have...
  • "The Monster PC" - Many Loud Fans
    Votes: 11 33.3%
  • "The Silent PC" - Quiet Fans
    Votes: 13 39.4%
  • "The Silent Assassin" - Water Cooling
    Votes: 3 9.1%
  • "The, Well, can't think of a name... PC" - Passive Cooling
    Votes: 0 0.0%
  • "Mixture" - Loud and Quiet Fans
    Votes: 6 18.2%
  • Total voters
    33
Kornowski
What do you prefer your PC to be:
Cool (Generally loud fans)
Quiet
Both
Passive Cooling
Water Cooling
At the moment, I've got one 92mm fan (44DB), two 120mm fans (44DB too :rolleyes:) and two 80mm fans, which are fairly quiet.
Though, I'm getting 35c idle and 50c full load...
I would prefer mine to be cool and quiet, but thats only possible at a price. But if i can find some middle ground then i'm fine with that.:)
Yeah, I know what you mean... Good Call! Sorry, off topic, COD4, Meanmans server?
I just use high-powered fans
Join the club! :P Doesn't the noise annoy you though?
I said "Monster"
I'm using the antec 900 with three 120mm fans, a 200mm fan, and Zalman 9700 cpu fan.
There really that loud just big.
I need the cooling due to the fact my cpu idles at around 45 C, but i also need the quietness so i can watch TV on my pc when in bed.
So every single fan in my PC is controlled (8 i think) so when i wanna watch somthing its whisper quiet, and i get temps of around 48 -52 just watching a dvd lmao
I also think water cooling gives worse processor temperatures than good air cooling unless you spend a lot more on good parts
When I take the side panel off of this PC, my room is a machine shop.. When I put it back on, it is pretty darn quiet. Whatever Antec did is working...
Mines pretty quiet, I have the P180 with 4 Antec 120mm tricool fans set to all low, and a passively cooled graphics card.
My 2.8 is a monster... Seriously. Not as loud as my lawnmower without a muffler, but it has a CPU fan rated at like 40 something dba...
The noise is kind of annoying, but I guess you get used to it, eh!
Idle I get 35c and load 49c, which doesn't seem right?
