Unfortunately, Intel are better.
The Athlon 64's were still better then the Pentium D's, Intel really pulled ahead with the Core 2 Duo's.amd used to be the best for gaming, at least until the pentium D came out (i think they started winning then...) then the core2duos came outta left field and pwnd peoples faces.
ehe..i guess a decent core2duo (e6550) is much better than the high end athlon x2 6000+?
AMD is for people that are so loyal to a brand that they refuse to go with something else, even when it is undeniable that the product is clearly inferior.
+1
It's funny that you say "unfortunately" because' I would have said the exact same thing.
You're friend is wrong, AMD used to be better at gaming back in 2005, but now Intel is doing a lot better. At the time of writing, the only reason I would recommend an AMD CPU would be if you already have an AMD Motherboard, and don't want to buy a new one.
At stock they perform on par
But E6550 overclocks better and consume less power
