Trying to build the most expensive computer possible
AleKing
I just signed up and wanted to say hi.
I'm currently getting my degree in networking and one of my projects is to budget different builds. The first needs to be under $250. The second is under $1000. The third is trying to build the most expensive computer possible. I was wondering what are some of the most expensive PC components you can think of.
I found a diamond in crusted mouse for $24,180.00.:eek:
http://www.fabstuff.net/products/664
Oh and if you can include a link that helps me too. Thanks!
you could easily put about 20,000 euro of hardware into it.
plus all the extra trim like external storage and what not.
Yes I can use newegg. But I'm not too worried about the $250 PC
Currently I have a system that totals about $50,000 but I'm still looking for more expensive stuff.
Wow! I was gonna try but I don't think I can build anything > $50,000. Can you list all the components of this $50,000 build?
Intel Core 2 Extreme QX9650 Yorkfield 3.0GHz $1,345.99
Asus Striker Extreme LGA 775 $339.99
Kingston Value Ram KVR667D2S4F5/2G 2GB 667MHZ DDR2 EC $467.55
Geforce 8800GTS Pcie 512MB GDDR3 $453.21
CineMassive Trio Gemini 24TW $7,999
The World's Most Expensive PC Mouse $24,180
Prometeia Mach II GT Cooler Unit $899.99
COOLER MASTER CSX 830 CX-830DSPD-01 Blue Aluminum ATX Full Tower Computer Case $999.99
Zalman ZM-GWB 8800 GTS Video Card Liquid Cooling Block $79.95
ZALMAN Reserator XT BK Black Reserator Water Cooling System $449.99
Bigfoot Networks Killer NIC M1 $249.99
Cisco Systems, Inc*Cisco Aironet 802.11a/b/g Wireless PCI Adapter*AIR-PI21AG-A-K9-10 $2,928
PNY Quadro4 NVS440 256MB 128-bit GDDR3 PCI Express x1 Video Card $409.99
Seagate Barracuda ST31000340NS 1TB 7200 RPM 32MB Cache SATA Enterprise Hard Drive $635
Grand total $47,082.23
I looked for the site with the most expensive parts
ASUS MAXIMUS EXTREME LGA 775 Intel X38 ATX Intel Motherboard $349.99
PNY VCQFX5500-PCIE-PB Quadro FX5500 1GB 256-bit GDDR2 PCI Express x16 SLI Supported Video Card $2,399.99
PHILIPS 2 X Blu-ray DVD Burner with Free 25GB Blu-ray Disc Black SATA Model SPD7000BD $459
CORSAIR XMS3 DHX 4GB(2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model TWIN3X4096-1600C7DHX $869
SILVERSTONE ZM1200M ATX12V / EPS12V 1200W Power Supply $399.99
Happy Hacking Keyboard HP Japan, PFU Ltd $4400
ASUS Xonar D2 7.1 Channels PCI Interface Ultra Fidelity Sound Card with Complete Dolby/DTS Sound Technologies $189
58,000
there are still lots of peripherals and stuff you could add
58,000
Might need one of these also, in case you need 3000 copies of something in just over an hour :) http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1221720&CatId=21
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1003992&CatId=512
You're going to need some software, too :) : http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=722314&CatId=306
Just shy of $70k. Of course, something this extreme is going to generate a LOT of heat. I don't suppose a cooling room is allowed as part of the project, is it? :D
