Check my Build please
Vestitor
Hey I want to know if these items will all work together.
GIGABYTE GA-MA69VM-S2 AM2 AMD 690V Micro ATX AMD Motherboard $59.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128043
Note: I need the motherboard to have a decent integrated video, hence the reason I would choose this one.
DYNAPOWER USA DP-50X.C617 ATX12V 500W Power Supply 110/230 UL/cUL E222785 $31.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817255009
AMD Athlon 64 X2 4000+ Brisbane 2.1GHz 2 x 512KB L2 Cache Socket AM2 65W Dual-Core Processor $59.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103774
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory $44.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098
TOTAL : $196.96
If you think any of these parts can be replaced for something better and keep it at about $200, that would be cool. ;)
Well, I really don't want a micro atx, but it was the best board I could find that included intergrated video and has some ability to overclock for about $60.
So it would be nice if you could find a non micro with similar specifications :cool: .
hmm.. not sure if you can. If you dont need a few more PCI slots or want two PCIe slots then just go with the micro ATX. There is no difference in performance between the chipsets, and one advantage is that you have onboard video that can be used.
to keep it under 40$ would be my goal for the power supply, that one's nice but it costs alot more then his original
Well, the link you gave me for the 4200 is a Brisbane not a Windsor, did you mean Brisbane? I probably go with the 4200 for an extra $5.
As for the power supply, I can't afford the extra amount the powersupply adds to it, even though it has a rebate.
The psu doesn't have to be 500, could replace for a good 400-450watt if possible.
If you could find a psu that is better than the one I have for within 5 dollars of the other one that would be cool.
The Antec gets 22A combined on the 12v rails, I'm not sure about the Dynapower because it doesn't state the maximum wattage for the 12v rails but if I were you I'd go with the Antec. 22A is a very good rating for a 350W and is plenty for your system, even if you wanted to upgrade to a mid-range standalone video card in the future. Plus, Antec is a very respected and well known brand, Dynapower....not so much.
Yeah, after reading some of the Antec reviews it seems pretty solid, so I will go with the Antec.
Thanks everyone for the help :cool:..
TOTAL : $196.96
Corsair had a DDR2-800 CL4 2GB Kit on Newegg for $37 after rebates. Dynapower seems like a poor company in my opinion. Take a look at the hec Orion 585W.
