No, OS X is can not be put on a PC.
I've seen my cousin working with a Mac OS X on his PC.... maybe I should ask him how the hell did he do it.
But then on a Mac i can install Windows.....
on Most PCs anyway.
No, you can not install OS X from an OS X install disc on to a PC. First off there is this thing called the TPM, which Apple has designed to only allow their installers to be on Apple based hardware systems. Next, each restore disc that is bundled with a system is batched to that system and won't run on hardware which is newer than that system because it is missing proper driver support. Lastly, it clearly states in Apple's software license EULA that OS X may only be installed on one Apple branded computer per a license.
Not to mention the second resource restore CD that comes with a mac, is a resource CD, which holds extras, not the OS itself.
Bottom line, if you want to run OS X get a Mac. If you have a PC and want to run OS X, install Linux and then go download OS X like shells and themes, and make it look like you are running OS X.
The OS X x86 project which you speak of that allows PC users to load native Darwin OS X, is illegal and hacks the TPM. However, there has been no legal recourse just yet against the project. I almost suspect Apple is waiting and biding its time and if they ever decide to allow PC users to load their OS, they will just buy out the project and then get law suit happy.
No! let him run mac don't be liek hey linux for life just get themes. It's pretty simple on how to run a mac on pc. vk3fcll just type in on google installing mac osx leopard on a pc using installation disc and hopefully if you come across the right link with user LTL writing it your on the right site![]()
IT IS ILLEGAL TO RUN MAC OS X ON ANYTHING BUT A MAC!
Duh. But it's his choice. what he does isn't written in stone. He can do it or not it's up the guy
No. It doesn't. It's pretty simple if you want to put mac on a pc then go for it.![]()
True. But ya know I would have bought a mac pro if they had 8800 ultras avalable. But people made kext's for the mac so the hardware can run at optimal.Sure, something that is developed for a specific platform which is designed from the hardware up runs better on something it is not designed for.
Also, TRUST me when I say that applications designed for the mac platform run better on a Mac. It is because everything that OS X x86 offers is hacked and reverse engineered, no one has ever given them source code. Where if you own a Mac, everything was developed with the tools given from Apple to run on that very exact and specific platform.
Which is why you sacrifice quantity for quality when you switch over to a Mac.
The only thing decent about macs is the OS. So I say go for it. Atleast you wont be getting any virus's.
