New PC, What do you think?
xXxRuinationxXx
Asus Crosshair II formula mobo
AMD Phenom X 9850 2.5
8gb DDR2 1066
2Tb HDD space (seagate baracudda's sats 300)
3x(three way hybrid) 512 ddr3 pci-ex 9800 black editions xfx
Vista Ultimate sp1 x64bit
asus triton cpu fan
thermaltake full tower armor+
alls I need is the 1000W ultra powersup.
wow. is it just a planned build or do you have it already?
intel pwns amd in the quad core department. ;)
its Overkill :D
a waste of money :D
i dont see what would take advantage of 3x(three way hybrid) 512 ddr3 pci-ex 9800 black editions xfx
and you should have gone for a Intel Quad,Not AMD :)
nice, but ther is no OS that reads 8gigs of memory, Intel quad is better the AMD...other then that, do u have it, or is it a plan and how much is gonna/did it COST!!!!!!!!!!!!!!!!!!!!:eek:
its Overkill :D
a waste of money :D
took the words out of my mouth! However, if I had that system..I would be proud of it, that is some hardware to gloat about, aside from the AMD CPU :P
Every Windows 64 bit OS can read 8GB of RAM. Vista x64 alone can read 128GB of RAM (except Home).
well the reason I went amd is everyone flames it, so I'm goinna give it a shot myself, worst case scenario is I shell out for a new mobo and cpu.
and it's all purchased except for one hdd and a power sup.
Asus Crosshair II formula mobo $348.00
AMD Phenom X 9850 2.5 $287.99
8gb DDR2 1066 $161.00x2
3x(three way hybrid) 512 ddr3 pci-ex 9800 black editions xfx $426.95x3
Vista Ultimate sp1 x64bit $243.00
asus triton cpu fan $119.00
thermaltake full tower armor+ $303.00
alls I need is the 1000W ultra powersup. $512.00
it ill be expensive and though seen as overkill by other members i approve of it as long as your going to keep it for a while, dont worry it'll last for ages. well done, it makes mine look like a speck of dust on it fan, beautiful system!
i read on the net that a company pushed it to 3ghz without adjusting the voltage and 3.1 with adjusting the voltage easily
so I figure 3g isnt a big deal, it will double my framerates and half my times
