3 water cooling kits in one system
super_xero
is it possible to have 3 water colling kist in one system e.g having the the cpu go to the radiator then go to teh pump then back to the cpu and teh same to the norhbridge and the gpu would it increase proformance because a geforce 7800 card cant remember witch one had its own water cooling system thanks
of course it would, instead of the heat building up as the water travelled from cpu to northbridge etc... it would be gone when it leaves, definately highly efficient but it would cost a lot and you would need 3x the amount of power as for 1 WC rig.
put a seperate power supply in the toolbox and run as much as u can fit in there :)
Yes you can.
________________________________________________________________________
I could cool my OPC with WC prabally allot better then you cans can, and cheaper, I'd use one of my extra fish tank pumps(large one, 1000GPH) and i'd plug it in to the wall(obvoilsy) and have a 10 gallon tank.
then this is how i would set it up, buy a new 10 gallon tank for 10$, but it under the desk, have the pump in it,(its a internal pump, like i'd ever use a good external one oh a silly pc :P ) now i would make moldings of the video card and RAM and things like that(im thinknig clay, I dont think that would harm it) then make this plastic of the mold and have it split up to each part at the begging, have it run though the molds then i would have a 5 gollong long tank, that i would build of of plasitc and 100% silicone INSIDE the bottom of the tank, that it owuld drain into after, then i would drill a hole in the right of the case, and have a continius siphon back down into the 10gllon at the bottom.
the clay would be afew bucks, and the plastic owuld be 10$, and the 10 gallon tnak would also be 10$
