4 pin psu power cable extender?
Shane
Super Moderator
Hello people,
Right ive just upgraded my case from a cheap Icute to a Coolermaster Dominator 690,Fitted everyting and it looks fantastic.
exept for one thing,All the cables from the Psu reach where they have to go no problems exept for the 4 pin cpu power one that goes into the motherboard....its way too short :P
Will this do the trick?
http://www.maplin.co.uk/Module.aspx?ModuleNo=34109
Many thanks :)
Great stuff,Il be picking one of those up this afternoon then!
Thanks alot chaps :) :good:
Got it and works fine.
and danny,If you do get one its 30mm long,NOT 33mm like the tech said from Maplin!
Thanks again :)
