40-pin EIDE interface cable same as IDE?
flame1117
banned
Is this differerent then a regular IDE? I think it is but im hoping not :(
becuase i can get one that has that, is 120GB 7200RPM and 8MB buffer for 39.99 and i have 25$ giftcard to that place.
eide just means enhanced. you can use that cable, but if u want speeds over ATA33 then you have to use a 40 pin, 80 conductor ribbon cable. its the ones with the finer ridges or lines on the ribbon cable itself, typically come with all new hdd's today. PATA drives that is.
Well i just relized that im a FRECKING IDOIT!
My mothboard supports sata, I looked on the box curois of dual-channle, because i didn;t remember, and right there in big letters "Serial ATA"
I was using my old IDE cables though, and my motherbord didn;t come with the other cables(how dumb) I assume most harddrives will come with the cable? or will i need to buy this cable seperate?
my friend recently bought two new sata drives from newegg, they did not come with a sata cable. he was lucky he found the the two that came with his mobo.
not sure if what he bought was OEM tho. i wanna believe that new sata hdd's come with sata cables tho. . .
They do. I've never heard of a case in which they did not come with the cable. Make sure, though, that you have a SATA power connector on your PSU (unless of course the drive has a standard 4-pin molex connector).
not sure, but i'll just use it as an excuse to get a better PSU if it doesn't.
I dont know if i can make it there by the time the sale ends :(
but frys has a deal(they have it every week, prabally untill they run out haha, thats how it is with most things) for the same thing but 160GB and Western Digital brand, i just never bought it ebcuase it was SATA aand i thought i couldn't use it.
So kI just got it, and now i have a question, i just set- it up to run as secendary, my current drive is a 40GB 4200RPM 2MB buffer regular IDE drive.
How much of a difference in speed do you think i would get if i put windows and all m y games and everything on the new drive and that that as my main drive? and then uise my 40 for extra stuff and backup?
that sounds like a good idea to me. that 40gb hdd sounds like a 2.5 inch laptop hard drive, its prolly not quick at all.
The new one you bought has an 8 MB Buffer.
Your 40 gig has a 2 MB Buffer.
Now then, if I'm right, the buffer means how fast it can transfer data, yeah? So that would mean it could do it 4 times as fast.
Please correct me if I'm wrong...
Nope, why would it sound like that :P It's just old thats all.
So, sincerandomally today im been getting errors and crap and i think i got some virus or something somehow, :/ evertime my sister using it...EVERY time...
So im just starting over anyways, i'm making this post inbweet updates, this is about the 15th restart so far, and this goes SO FREAKING FAST compared to before.
old HD
4200RPM
2MB buffer
regular IDE
NEW HD
72000RPM
8MB Buffer
IDE-E(nhanced) Sata
I didn't think i would see such a diffference in start up loading windows and all that, I know some of it not loading instant messaging and stuff like that but that's just a few small programs, and when i installed windows last time rigth away it was never that fast.
and I dont know why people dont like SP2, just disable the new Windows Secuiry, and its fine, plus it makes windows fun smoother and start up faster(enough to notice from SP1 and SP2)
althought I have been doing this from 6:00 and its 9:28 and im not even half way done I think it was well worth it, can't want to see if it makes a differene in games for loading graphics or something.
I'm still just installing updates for windows geeze there are so many that you have to restart inbetween.
and I didn;t rememeber the installation taking soooo long. they should make it so you choose everything at the begging then you leave for a while and come back at least, instead of every 6 minites you have to choose a option or press "ok" to move on. retarted.
I hope i dont have video card driver problems like last time I installed it :(
Well time for another restart, i'll prabally post 1 message inbwteen for now on heehee.
UPDATE: woot! 10:46 and i finished installing windows, windows updates , nortan, nortan updates, and videocard/sound/other varous drivers.
Just for games now, which will prabally take me a few hours also, sonsidering i have almost every steam game install WoW and startcraft and all the other blizzard games, and thats just what I plan on going to night, that and cuztomizing windows and my desktop again.
caches mostly work by keeping data that is accessed often in the memory cache for quick retrieval. it just means that it can store 4 times more data, which in the end, does help speed/performance :)
most laptop hard drives run at 4200rpm, that why i thought that. altho, they are getting faster drives now :D dont think i have seen many 3.5 or 5.25 inch hard drives that spun at that speed, altho i do have tons of old drives, and i have no idea how fast they spin.
You're not right, but you're not wrong. The larger buffer can give a longer burst transfer which is much faster but then it has to go into sustained which is quite slow in comparison.
40-pin eide interface cable
is this differerent then a regular ide? i think it is but im hoping not
becuase i can get one that has that, is 120gb 7200rpm and 8mb buffer for 39.99 and i have 25$ giftcard to that place
not different but to get the most performance out of a HDD make sure to get the 80wire, 40pin cable rather than the 40wire,40pin. the 80wire version sometimes is called a ata66/ata100/ata133 cable
HDD 101.
HDD 101.
Well i assume thats what i am using becuase I used what came with it, thanks for the advice everyone!
