8 Pin P8 /12V to 4 Pin P4 /12V Power Supply Converter Cable
blue21
Does an 8 Pin P8 /12V to 4 Pin P4 /12V Power Supply Converter Cable even exist? If so, were on earth can I get one?
No, that the opposite of what i need. See, I have a motherboard that needs a four pin connector, but I am able to buy a power supply for cheap that is exactly what I need except that it has an 8 pin connector instead of a four pin.
no, the jacks at the end are opposite. I was able to find what I need on the performance pc website, thanks.
Also be aware that the 8 pin connector will often break apart to allow you to use half of it as a 4 pin connector.
It's an EPS 12v connector. Used for workstations and servers. Just figure out which wires you need, pull them out of the plug and put them in a four prong plug.
