9800pro need special power thing?
93glouden
my frind says a 9800pro needs a special power wire thingy to work, is this true, i thaught it only needed a 4 pin molex connector to work...... :confused:
I know all you need is a 4 pin molex on the Gigabyte model cause I had one. I'm sure if you look on most manufacturers website you'll find all you need to know.
Nope nothing special like that. just be sure the power supply is large enough to supply extra power to the video card. at least a good 350watt psu.
