Are all these parts compatible? Double checking
sef24
So a friend of mine wants to build his first computer, I have helped him in the process but I would like to know if all these parts will work together.
I do know that some of these are overkill but this is how he wants it, and I wont argue with him, so no need for suggested changes :) thanks though.
MotherBoard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131641
PSU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
CPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115211
GPU:
sapphire 6870
OS:
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
Hard Drive:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
DVD:
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106335
RAM-12GB:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233146
Azza Solano:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811517004
Everything will work. He only needs 600W for that build though. And 12GB RAM is a waste too. Otherwise, all good :good:
MotherBoard:
PSU:
CPU:
GPU:
sapphire 6870
OS:
Hard Drive:
DVD:
RAM-12GB:
Azza Solano:
In that budget I would have gone with a completely different build.Anyways the above build is completely compatible.
And ohh GOD 12 GBs of RAM.6GB for use and the other 6 for show-off
I knew Ram would be mentioned haha. I told him 4 gigs is just fine, 6 at max if he really felt the need, 12g... yea idk.
He will probably be subjected to upgrading in the future so I went ahead and told him to get a 750+ (for a possible crossfire)
Thanks for the quick replies, didnt want to find out that something would work
I'll give you a heads up on the AZZA case. Its really a nice cse, but just has one problem. If you decide to get a taller CPU heatsink, it will hit the side fan because of the fans size and placememt. I've owned all three and would recommend the NZXT Tempest EVO or LIAN LI Lancool PC-K62 over the AZZA.
