Are these parts compatible?
Thebryzor
Building my first desktop computer for video rendering/gaming and I was wondering if these parts are compatible or not.
SSD:
OCZ Vertex 2 OCZSSD2-2VTX60G 2.5" 60GB SATA II MLC Internal Solid State Drive (SSD)
PSU:
CORSAIR Gaming Series GS800 800W ATX12V v2.3 SLI Ready CrossFire Ready 80 PLUS Certified Active PFC High Performance Power Supply
Memory:
G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBSR
Motherboard:
ASUS M4A89TD PRO/USB3 AM3 AMD 890FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Processor:
AMD Phenom II X6 1100T Black Edition Thuban 3.3GHz, 3.7GHz Turbo 6 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Six-Core Desktop Processor HDE00ZFBGRBOX
Graphics Card:
EVGA 02G-P3-1386-KR GeForce GTX 460 (Fermi) 2GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Thanks a bunch! :D
Get a AM3+. Preferably with the 990FX to get the ability to SLI that GTX460 in the future. Also will give you the ability to use the new AMD processors whenever they actually release them.
Also, unless you are doing Video encoding/editing or other highly threaded applications, get a quad core (955 are the best) and save you some more money.
Yes. all compatible. However, I suggest you get intel instead of AMD. If you really want AMD, get something support AM3+. Since you are using GTX460, no point for 890FX chipset as it do not support SLi. Get 990FX or get other cheaper mobo
