are these parts ok
Ryan Stephens
I want it all to work and are these parts compatiable with my motherboard?
CPU
AMD Athlon II X4 640 Socket AM3 3GHz 2MB L2 Cache Retail Boxed Processor ADX640WFK42GM
http://www.ebuyer.com/product/242140
motherboard
MSI 880GM-E41 880G Socket AM3 onboard graphics 8 channel HD audio mATX Motherboard
http://www.ebuyer.com/product/244433
ram
Kingston 4GB (2x2GB) DDR3 1600MHz HyperX Blu Memory Kit CL9 1.65V Non-ECC Unbuffered
http://www.ebuyer.com/product/234975
optical drive
Sony Optiarc AD-5260S 24x DVD±RW & DL SATA Optical Drive - OEM Black
http://www.ebuyer.com/product/220986
Graphics card
http://www.amazon.co.uk/Sapphire-11...YGM0/ref=sr_1_3?ie=UTF8&qid=1303651830&sr=8-3
HDD
Samsung F3 HD103SJ 1TB internal Hard Drive SATAII 32MB Cache 7200RPM – OEM
http://www.amazon.co.uk/Samsung-HD103SJ-internal-SATAII-7200RPM/dp/B002MQC0P8
case and psu
cool master case and power supply
http://www.ebuyer.com/product/220861
motherboard compat list for cpu
http://www.msi.com/product/mb/880GM-E41.html#/?div=CPUSupport
my CPU product key ADX640WFK42GM
matched
http://www.cpu-world.com/CPUs/K10/AMD-Athlon II X4 640 - ADX640WFK42GM (ADX640WFGMBOX).html
rest of parts compabilty list
http://www.msi.com/product/mb/880GM-E41.html#/?div=TestReport
Are these parts ok for my motherboard?
Am3 is an old socket. AM3+ will support all AM3 cpus and the new Zambezi processors that are to be released soon, should you want to upgrade later.
as for the PSU and case, Cooler Master is not a reliable brand of PSU. as for the case, it probably doesnt have many cable management options at all.
both of them look like they have good cable management (thats a good thing). though I have never dealt with that brand.
If you can spare teh extra, go for a HAF912.
Should I get that motherboard?
Personly I thought it is good for the money. And for the good reviews though out the Internet.
also look for atx, not matx, just have a few extra features and only other diff is the size, the second he linked is matx, but matx will do just as well for what you want i guess. also since i can tell you want to save money you might want to look at a cx430 instead of the cx500, still plenty of power for that, and if you want to game then a better gpu and lower cpu might be better, otherwise a gpu is unneeded as the onboard gpu's are plenty to do just about anything but gaming
Specs
HD5570 HD5670
650MHz 775MHz
400 processors 400 processors
128 bit DDR3 1GB 128 bit DDR3 1GB
the 5670 is faster, but same specs as an OCd 5570.
Ok I have put some parts together and I want to know what you think. And if I should change some or a slight incombailtity with size power or if they work ok. You can change them but keep in mind this is a low budget gaming pc.
CPU
motherboard
ram
optical drive
HDD
http://www.amazon.co.uk/Samsung-HD10.../dp/B002MQC0P8
casecom case
http://www.ebuyer.com/239238-casecom...an-k5-9388blue
GPU
http://www.ebuyer.com/255465-xfx-hd...-displayport-pci-e-graphics-card-hd-567x-zaf3
PSU
CM GX PSU
http://www.ebuyer.com/278634-corsair...mpsu-500cxv2uk
thanks for all your input
Nevakonaza
wolfeking
daisymtc
jonnyp11
bennyboy
