Fatback
I finally decided to get me an after market HSF. So the Arctic freezer was the first one that popped in my head but I got a couple of questions.
1. How wide is it with the fan on the heatsink from what a see it would be 211mm around 8in
that can't be right.
2. Is it possible to put a different 92mm fan on it
3. Should I get this instead http://www.newegg.com/Product/Produ...5233014&cm_re=xigmatek-_-35-233-014-_-Product.
The xigmatek I have used many times and know what it can do. I have only used the arctic freezer once and it was like a year ago and I don't remember much about it. I'm just looking for somethinkg around $25-$35 maybe a little more I don't really won't to go higher then that as I won't be OCing at all. I'm just trying to get better load temps then 55C. So which one should I go for or do you have any suggestions. Also I don't have a lot of room in my case so the smaller the better.
