Basic water cooling system AMD
jasonn20
I have been curious as to how much for a basic but effective water cooling system for a AM3 MB. I like the design where the radiator is mounted where the exhaust fan is and goes directly into a cpu waterblock. Also the the type that is mounted in a 5.25 drive bay then to the cpu block. If the price is decent then I may convert. (within a $100 dollars)
Are ther other alternatives like going to a hardware store and making my own?
Thanks
Case: CM Storm Scout
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106077
