Best Graphics Card Cooling Solution
irt2
I want to know what you use to cool your high-end graphics card? What is the biggest and the best, and more importantly what makes it that way.
Thanks
-Ian
well, I don't have a lot of money so I have the tower facing the air conditioner with the lit off and it works like a god, i have a ati radeon X800XL 256MB OC to 440 mhz and the highest temp i have gotten is 48D os there you go. convetional methods. but if you have money, you should get your entire computer a water cooled system.. sounds good? here some good water cooling accesories: http://www.newegg.com/Product/Product.asp?Item=N82E16835127011
water cooling can drematically cool your system but just be carefull archangel water cooling rig leaked and ruined her 2 6800 gt in sli :(
i dont have watercooling ;) it was suicide mayne's cooling.
water cooling can cool pretty good. however, its pretty work intensitive.
i prefer heatpipe heatsinks over it anytime :)
See I'm looking to see what cooling options I would have for a BFG Geforce 7800GTX, excluding water cooling just because I dont have the money/courage/space to get a proper setup going in my rig. What would be my best bet besides some exuberant refrigeration system that costs my first born to buy!?
Thanks
-Ian
lol that's right the show off girl with the 10000 score on the 3dmak lol, so funny and yet i feel bad for the cards..
I can see little red flags waving in front of me that says "this might not be the most practical of applications..." :D
i like the aircond. idea the best. i may do that....somehow...*thinks hard*
it would be loud as hell.!.
but open the side of the case, take it off.
mark where the conditioner lays on it and cut a square.
now take blocks of wood to hold it up and WALA!
you have a A/c in you computer.
im gona think on this one...
