Build Parts
harry clemance
i would like sagestions on parts for my first desktop build. i would like to spend £600 in total but can be flexable.
spesifications: Processor i7 if not i5
Motherboard compatable with Processor (dont know much about motherboards)
Ram 4-8gb DDR3 1333/1600mhz
Graphics Card 1gb DDR5
Blu-ray and dvd rewriter
1 TB hard drive 7200 rpm
Relavent powersaply
Relavent case
19" screen
Hi,
Do you intend to do any gaming on this system?
Would you consider an AMD build?
Intel Core i3 2100 3.1GHz Socket 1155
http://www.ebuyer.com/product/254976
Gigabyte GA-P67A-UD3-B3 iP67 Socket 1155 7.1 Channel Audio ATX Motherboard
http://www.ebuyer.com/product/259593
Corsair 4GB (2x4GB) DDR3 ram
http://www.ebuyer.com/product/247673
Samsung HD103SJ Spinpoint F3 1TB Hard Drive SATAII 7200rpm 32MB Cache
http://www.ebuyer.com/product/173804
PowerColor HD 6790 1GB GDDR5
Corsair 600W CX PSU - 2x PCI-E 6x SATA
http://www.ebuyer.com/product/241000
Xigmatek Utgard Black Mid Tower Case
http://www.ebuyer.com/product/191871
LG blu-ray drive + DVD writer
http://www.ebuyer.com/product/195147
19 inch monitor
http://www.ebuyer.com/product/167713
I think this would cost a bit more than £600, you can add the prices of these parts by yourself. You can always change the graphic card to something cheaper like HD5670
http://www.ebuyer.com/product/190977
Anyway, I don't think you can afford an i7 or i5 with £600 budget, but i3 2100 is good CPU for gaming.
Also, i3 2100 can't overclock. So, I'm assuming that you won't overclock your CPU.
its only casual gaming so i hardly ever change the graphics settings from normal.
yes i would consider amd just never think of them as i dont know much about them.
the price of that was a bit much if it helps i can use the screen i have already got
