Building a computer (changed parts)
supra8
How would this be for playing MMO's such as vindictus and pwi
Also does this motherboard have a sound card built in?
MotherBoard: Asus M4A77T/USB3 Socket AM3, AMD 770 Chipset, DDR3 1800(O.C.)/1600(O.C.)/1333/1066Mhz, 8-Channel HD Audio, Gigabit LAN, 2x USB3.0+10x USB2.0, 6x SATA, ATX
http://www.canadacomputers.com/product_info.php?cPath=26_340&item_id=032050
Processor: AMD Phenom II X4 955 Black Edition (125W) Quad Core Socket AM3, 3.2GHz, 8Mb Cache, 1800MHz HT, 45nm
http://www.canadacomputers.com/product_info.php?cPath=4_64&item_id=027383
Video Card: PowerColor (AX5770 1GBD5-H) ATI Radeon HD 5770 Chipset (850Mhz) 1GB GDDR5 Dual Display Dual DVI/HDMI PCI-Express 2.1 Graphics Card
or
XFX HD577AZNFC Radeon HD 5770 Video Card - 1GB GDDR5, PCI-Express 2.0, CrossFireX Ready, Dual DVI, Display Port, HDMI
(which is better?)
http://www.canadacomputers.com/product_info.php?cPath=43_557_558&item_id=028564
http://www.tigerdirect.ca/applicati...1&csid=ITD&recordsPerPage=5&body=#ReviewStart
RAM: OCZ (OCZ3G1333LV4GK) DDR3 PC3-10666 1333MHz Gold Edition Low Voltage 4GB (2x2048MB) Dual Channel
http://www.canadacomputers.com/product_info.php?cPath=24_311_312_611&item_id=025892
Power Supply: OCZ ModXStream Pro 600W Power Supply
http://www.canadacomputers.com/product_info.php?cPath=33_443&item_id=019983
CD Drive: LG GH24NS50 Black SATA DVD-Writer 24xDVD+R/-R 8xDVD+RW/6xDVD-RW 16xDVD+R DL 12xDVD-R DL 48x CD-R 32xCD-RW OEM
http://www.canadacomputers.com/product_info.php?cPath=3_61&item_id=027988
Case: Apevia Black/Black X-Plorer ATX Mid-Tower Case with Clear Side, Fan Controller, Front USB and Firewire Port
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1384989&CatId=1509
thanks
GTX 460 instead, and pretty much all mobo's have built-in soundcards.
It actually says ''8-Channel HD Audio'', and try to get everything from one store.
And I'm not sure, but I think 600watt is overkill. You also forgot a HDD.
overkill as in i dont need that much?
So will the power supply this case come with be good enough? http://www.canadacomputers.com/product_info.php?cPath=6_112&item_id=028695
HDD i got 1 forgot to post
http://www.canadacomputers.com/product_info.php?cPath=15_210_212&item_id=010671
bump
didnt want to make new topic but how would all that work with this case and the power supply it comes with, minus the case and the power supply posted below?
i am not sure about 550watt. and your previous power supply was not overkill. its always better to have more than enough than not enough.
ok, im for sure getting 5770 now, i just dont know if powercolor gives better performance or xfx does.
Ok, i cant spend any more money and i think im sticking with those parts listed above minus the power supply and case and adding in the coolermaster usp 100 and 550 watt power supply. Is there any overheating of such that i might have to be worried about? And how can i fix that.
The case in your list is terrible by the way, i had for for about 2 months and ended up replacing it with an antec 1200.
the apevia x-plorer or coolermaster 100 usp?
And xfx i heard they brake alot but better warranty, thats about it.
The power supply you have chosen with the case is poor quality. Don't ever go cheap on a Power Supply. It is the backbone of your system. Cheap power supplies can cause performance issues, burn out and damage your system. You may have to save some more money to get decent quality components. This power supply is good:
Corsair TX Series CMPSU-650TX 650 Watt Power Supply - $90
http://www.canadacomputers.com/product_info.php?cPath=33_441&item_id=015708
OCZ does not make decent quality DDR3 memory either from what I have heard. I would go with another brand of RAM.
Yes, there will be a huge difference, seeing as the new motherboard you're looking at only supports DDR2 memory, not DDR3.
And the phenom II x4 955 BE is alot better than the newer one you linked.
