I will mostly be using it for iRacing and NR2003, Sims3, FSX, and maybe some smaller games. How does it look, anything you would change?
Case: COOLER MASTER HAF 932 Advanced
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
Motherboard: MSI 890FXA-GD65 AM3 AMD 890FX SATA 6Gb/s USB 3.0 ATX AMD
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130565
CPU: AMD Phenom II X4 965 Black Edition Deneb 3.4GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
Video card: ASUS ENGTX460 DirectCU TOP/2DI/768MD5 GeForce GTX 460
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121390
Hard drive: SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
Power supply: CORSAIR CMPSU-750TX 750W ATX12V v2.2
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
RAM: G.SKILL Ripjaws Series 8GB (2 x 4GB)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
CD-ROM: LG Black SATA DVD Burner - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136236
I've decided to go with AMD instead of Intel simply because of price, the games i'll be playing will not need top of the line speed.
