Any of the molex cables coming from your power supply will power the fans just fine. Only downside to it is that you can't control the speed of the fans, unless you get a fan controller, which acts as a go between and allows you to change the speed of the fans, to keep temperatures at reasonable levels, whilst making your system quieter
