Case Labs TH10, 4way classifed, gtx590s and water cooling
Juggalo23451
Case- Case Labs TH10
Cant have music cause of the copy right deal
[UT]nXqMzXQ4xcs[/UT]
Specs of build
Evga 4 way classified
Intel 970 ordered
2 gtx590s
Muskin ram 6-12gig
2tb wd caviar black
ssd 128 crucial c300
psu 1500 silverstone
Water cooling
primochill Orange 1/2x 3/4 tubing
enzotech compression fittings 1/2x3/4
2 MCP35X pump
Koolance 402x2 reservoir - run pumps in series
White HK
Koolance water blocks
Koolance sli adapter
2 RX 480 rads
1850 Gentle typhoons pull
ek 4 way classified water block
loop order will go
res-pump-rad-gpu-gpu-rad-cpu-chipset-res
Reason I have the chipset last is because it has the most restriction
[ut]AK0uCTDpqAk[/ut]
[ut]kCsDhtAQmAk&NR[/ut]
[ut]tkOw_pQbMYw[/ut]
[ut]UAzje5hQ6bM[/ut]
[ut]pK7gb_HR6PA[/ut]
only temp still needs work
GPU TEMPS in vid
[ut]aukq8l7AhKc[/ut]
load temp
[ut]4A8wOzQnKMc[/ut]
[ut]o13iKXvY10w[/ut]
[ut]vU-H8bf0U6M[/ut]
[ut]2oHrl-maH9s[/ut]
[ut]XkFDW6aE2Io[/ut]
[ut]3whaNMk6eAc[/ut]
[ut]AZFhQI7j3KQ[/ut]
MY PSU White OMG :)
[ut]5_AlAuhIZ00[/ut]
[ut]L15uVMYgk9o[/ut]
NEW LOOP
[ut]mfpeQ0cj79o[/ut]
[ut]g7smRFYGcbI[/ut]
