emac227 New Member Sep 10, 2011 #1 i recently purchased a coolit system and the fan wont fit in the back of the case so i was wondering if i could vent it out to the side or somewhere else, does it have to be the back?
salvage-this Active Member Sep 10, 2011 #2 It does not have to be the back but that makes the most sense. Why won't it fit?
just a noob Well-Known Member Sep 10, 2011 #3 Just so long as you don't put too much stress on the tubes, you'll be fine.
emac227 New Member Sep 10, 2011 #4 the rad hits the side of the case where the panel goes on, its about 2 mm too big i might just get a new case although this one is still brand new
emac227 New Member Sep 10, 2011 #6 salvage-this said: I see. Can you use the top vents? What case is it? Click to expand... http://www.canadacomputers.com/product_info.php?cPath=6_112&item_id=026868 this is my case, the top vents are open with no fans but i dont think it will fit that way either
salvage-this Active Member Sep 10, 2011 #7 try the top mounts. I have the M59 and it is pretty much the same case. You should have more space up there.
emac227 New Member Sep 10, 2011 #8 salvage-this said: try the top mounts. I have the M59 and it is pretty much the same case. You should have more space up there. Click to expand... when i tried to fit it in the first time on the top, it didnt seem like it would fit
StrangleHold Moderator Staff member Sep 10, 2011 #9 What size radiator did you get with it? They come with a 92/120/140 and 240mm.
emac227 New Member Sep 11, 2011 #10 StrangleHold said: What size radiator did you get with it? They come with a 92/120/140 and 240mm. Click to expand... i only seen one size and the case fan on it is 120
