counter-strike problem help!
brettbt
ive been playing cs for 2 years now and i lan and bla bla... anyway i have a bad computer and whenever im playing cs now it restarts my computer or freezes and i have to reconnect. it happens every 4 rounds or so. my computer is hot so i think it might be the fans and the temperature. but also it could be the power supply cuz it turns of sometimes and i have a geforce 6800 with a 350 watt power supply 12A @ 12V. is this happeneing to anyone or know how to help me please help! thanks
what kind of computer are you playing on?
i know when i used to play on a laptop, it would power off by itself for the same reason, because one of the fans inside wasn't working (and it was a laptop, which is pretty stupid to play on as it is).
So my guess from experiance is you are correct, your computer is overheating... but it could be something totally different.
phil
I suggest getting a better psu. If you don't have a good psu, you could possibly hurt your other components. Read PSU 101.
Trouble playing cs 1.6?
What computer you got? A commodore?
12A is not enough to sustain a stable 12V rail you need at least 20A and with that big graphics card in there you should be looking at more.
I think this site can heLp u :) And Also you can find lots of thing about CS.
Why R U still waiting?Come and See ;) www.turkforum.net
Yeah cause your computer sounds good enough, especially if youre talking about CS 1.6 ofcourse, but i should be enough for Source too
