nikecpikec7
I cleaned my computer with air and after i started it at home the cpu(fan) is making such a weird loud noise + on HWMONITOR the cpu has 100 degrees.
Help please
Help please
No i was cleaning it like always till now, opened computer and just aired inside from safe distance so the dust went out, that’s all, no touching componentsHow did you clean the fan? With compressed air? Did you hold the fan in place? If you didn't you likely damaged the fan.
His point was, if you didn't hold the fan in place when you sprayed the air, its possible the fan spun too fast and is now damaged. You'll probably have to replace the fan now.No i was cleaning it like always till now, opened computer and just aired inside from safe distance so the dust went out, that’s all, no touching components
I have water coolingHis point was, if you didn't hold the fan in place when you sprayed the air, its possible the fan spun too fast and is now damaged. You'll probably have to replace the fan now.
Going back to your first post.I have water cooling
Ok my bad , but still somewhere around cpu is the sound, very loudGoing back to your first post.
There's still fans involved lolI have water cooling
You need to allow anyone with the link to access those files. Right now we have to request access.IMG_9097.MOV
drive.google.com
IMG_9096.MOV
drive.google.com
