CPU Speed changing dramitically Please help!!!
lavrentis
Hello I was looking in CPUZ when i noticed this..
my specs are on the pictures below...look at Core Speed and Multiplier!!
I want to overclock it from 2.2ghz anyway.. My motherboard (ASUS P5LP-LE) bios has no CPU functions so how do I change this please..
screenshots...
Please help
Thanks
Thats usual for an Intel CPU... its called SpeedStep (I think) when the CPU is not being used at high capacity it is clocked down. This can help reduce heat / increase the lifespan etc...
You can change the settings in your BIOS is you don't want it to do that.
Hello,
thank you for your reply but I cannot change anything in my BIOS to do with my CPU. They are all grayed out, I can see the settings just not touch them.
I have Award BIOS or something like that
erm...I don't think I can help you with changing it in your BIOS. If you post your motherboard make / model though someone might be able to assist! :D
Your PC is in the "save money" mode.
I believe it is called C1ST and EIST which should be in your BIOS options to disable. Its simple to disable but if you don't overclock at all I would leave it on.
I was told it doesn't work so well with overclocked processors which sucks....I would love to have my quad idle @ 1.0ghz when I am afk downloading demos and crap all night. Id save a lot of cash every month doing so.
Twist86, it is not in my bios mode.
Here is a pic of my BIOS screen
I can only access blue text
will flashing the BIOS unlock all these settings?
This is the advanced page of your BIOS. Have you looked over under the "Power" tab? Do see something about Speedstep over there?
Also...the ASUS P5LP-LE motherboard has no ability to OC within the BIOS. It was not designed to be overclocked easily. Where you looking to use ClockGen/SpeedFan or something of the sort?
if C1E/Speedstep/EIST is not listed in your BIOS anywhere then there is no way to disable.
If it is, but blacked out either look for a modded BIOS for your motherboard, or go other to somewhere like XS & ask there, Theres a guy who mods BIOS's there who's pretty good at it, maybe he will be able to help you, I can't remember his name but I believe he's in teh WCG section somewhere
I have checked in all tabs and there is nothing else.
THis XS fellow, I have googled him but no result. Please may you help me with a link?
Thanks
By the way, if you are serious about overclocking, you would be much better off with a newer and more capable motherboard.
Be very careful with using modified BIOSes. If you are not familiar with restoring your BIOS to its factory state without being able to boot the motherboard, stay away!
Now, that being said, if you want to experiment and don't mind potentially killing your computer (and/or you have a backup), have fun with it. You don't learn if you don't try. ;)
I just saw on youtube someone overclock my CPU and I wanted to try it out :(
Thats all to be honest.
I get great frames though in games and I checked in some games I see in CPUZ that my CPU is 2.2Ghz but in games like Burnout Paradise where I get a lock of 60 frames which is maximum I think the CPU goes down to 1.2Ghz.
Strange.
Strange.
Not really. Some games limit their framerates. BF2142 stops at 100, but
if I open the console and type: gamelock.fps 300 then I can see
that I'm actually getting 200-250 on some maps. Depends on the game.
New motherboard?
Gees, I have spent enough on it and its not all that bad surely?
No, it is not a bad motherboard. I did not mean to imply that at all. That motherboard is just not designed for overclocking. That's all. :)
I understand. Don't loose heart, it may be possible to overclock your motherboard if you really want to. Just be forewarned that you can break things if you are too reckless.
It sounds like you have not done any overclocking before, correct?
Yeah I have never done it before which is why I wanted to try it out. Is it safe for me to do it, temperature wise because at idle both my cores are around 20-22 degrees?
