Desktop building parts help
AeroNV
I know a little bit about PC building but I still need some help. I have found this so far but I still don't have power supply.
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
Hard Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131873
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814121442
CD Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16827135224
Memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820104344
CPU and Operating System combo
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1224793.19-103-996
Again, I still don't have a power supply but need help finding one and I would like to be able to run games like Arma III at a decent speed and not low graphics. I would also like some help with lowering the price (it is $606.92 right now) of all this because I wouldn't like to spend a lot on it.
Arma III is a very hard to run game and a HD 6670 might not cut it even on low. The board isnt good, the os /cpu link doesnt work, the hdd is a terrible choice for your your budget. This build looks nice: http://balloftech.com/?p=302 Should run arma 3 at low or medium settings well.
I think he hates ASUS, not entirely sure why. I've never used that particular board before but I've never had any problems using or recommended ASUS boards.
The graphics comes from the CPU so the MoBos will support it but check what video ports they have.
What do you mean by video ports?
It's a video hookup for the monitor. It's VGA (Dsub), DVI and HDMI so your monitor should be able to hook up to the MoBo you picked.
Same with the video cards as they'll have those ports too. Not all will have these three ports together.
Yeah, the new generations of GPUs are powerful and power efficiant, a good 380W would power it just fine. And antec is good. And i dont hate Asus, i just would go with gigabyte, have heard better things about there support over asus. The 7850 is a lot better than the 650 ti, get the 7850 by saphire for $165.
Umm No, Windows 8 is a great OS and i cant think of a single newer game that wouldnt work with it. Ask any user on here who has W8 and 9/10 will say it is a good OS, and the same or better than W7.
Windows 8 is still ironing out the kinks with some games. Windows 7 will function better with some older games that 8 won't play nice with. If you've got older games you want to play then get 7 but if not and you're going to be playing mainly newer games then 8 is fine. If you can play with each OS and see which you like better that would be good as well.
