Desktop Wireless Card Problem. Help
joeby
Hi, ive got a weird problem with my wireless in my pc, started using it back the other day and wouldnt connect to my wireless hub, took the antenna off it then picked up only 1 bar of signal and connect with no problems, it works okay at the moment but due to low signal it is slow and drops out sometimes. Anyone know how to fix this?
Uninstall the driver and reinstall it. Put the antennae back on the card. Make sure you enter the correct security key if using security.
