butter New Member Jul 25, 2007 #1 it's prob a silly question, but i got confused.. so, is there any difference between 20+4pin and 24pin types of connectors? ps. i read the whole 101 section, and searched thru the forum.. didn't help much
footballstevo75 Active Member Jul 25, 2007 #2 No. It's just if your motherboard has a 20 pin (pretty old) , the 20 + 4 pin will work with that also.
butter New Member Jul 25, 2007 #3 footballstevo75 said: No. It's just if your motherboard has a 20 pin (pretty old) , the 20 + 4 pin will work with that also. Click to expand... thanks.. i guess the topic's closed.
