Disk Cleanup Problem, Help please!!
jake12
Everytime when i use diskcleanup it would delete everything but my Compress Old Files. So i serched on it and I did this:
http://support.microsoft.com/default.aspx?scid=kb;en-us;812248
Now when I click Disk Cleanup, I only see:
Downloaded Program Files
Temporary Internet Files
Recycle Bin
Temporary files
Catalog files for the Content Indexer
I would like to know how to get the "Compres old files" back, and if I should get it back.
Thanks alot, I'd really appriciate your help!
if you did this step:
4. On the File menu, click Export, and then click Desktop, type VolumeCaches in the File name box, and then click Save.
You will be fine...
Read:
Note This step creates a backup of the VolumeCaches registry key. If you experience any problems after you complete the steps that are listed in this procedure, you can use this backup to restore the VolumeCaches key to its original state. To restore the key, double-click the VolumeCaches.reg file on your desktop, and then click Yes.
