MB - GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX -
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
CPU - E6750 -
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115029
Memory - CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145590
Card - 8800GT 512mb -
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150252&Tpk=8800gt
HD - Western Digital Caviar SE16 WD2500KSRTL 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136037
PS - Rosewill RP500-2 ATX12V v2.01 500W Power Supply
http://www.newegg.com/Product/Product.asp?Item=N82E16817182016
Case - COOLER MASTER Centurion 5 CAC-T05-UW Black Aluminum Bezel , SECC Chassis ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.asp?Item=N82E16811119068
Cd\DVD - SAMSUNG Black 20X DVD+R 8X
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151153
Mouse\Keyboard -
http://www.newegg.com/Product/Product.aspx?Item=N82E16826104178
http://www.newegg.com/Product/Product.aspx?Item=N82E16823175103
Vista 64 bit home edition
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116204
Total: 1023.89
It will be used primarily for gaming (Crysis). Does it look good?
As for the videocard, when does the updated model of 8800GTS come out? I heard it is expected to perform better than the GT, is that true? What about ATI HD 3800, which is supposed to support DX10.1?
CPU - E6750 -
Mouse\Keyboard -
Total: 1023.89
