First Build Might Need help!
wantedelite
My friend's dad works at NCIX and he could get me discounts, so I am buying from NCIX! This is my first computer I am building I used the pc builder form the site and his dad told be the pieces I should get.
Parts:
http://ncix.com/products/?sku=34598&vpn=BX80601920&manufacture=Intel&promoid=1042 -Intel Core i7 920 Quad Core Processor LGA1366 2.66GHZ Bloomfield 8MB LGA1366 4.8GT/S ~ $299.99
http://ncix.com/products/index.php?sku=35760&vpn=GA-EX58-UD3R&manufacture=Gigabyte -Gigabyte EX58-UD3R ATX LGA1366 X58 DDR3 2PCI-E 2PCI SATA2 RAID Sound GLAN CrossFireX Motherboard ~ $235.86
http://ncix.com/products/index.php?sku=37431&vpn=HD489AZDEC&manufacture=XFX&promoid=1042 -XFX Radeon HD 4890 XT 1GB 875MHZ 1GB 3.9GHZ GDDR5 PCI-E 2XDVI HDTV Video Card ~ $239.99
http://ncix.com/products/?sku=21123&vpn=NINE HUNDRED&manufacture=Antec -Antec Nine Hundred Mid Tower Gamer Case 900 ATX 9 Drive Bay No PS Top USB2.0 1394 Audio ~ $126.31
http://ncix.com/products/?sku=26415&vpn=CMPSU-750TX&manufacture=Corsair&promoid=1042 -Corsair TX750W 750W ATX 12V 60A 24PIN ATX Power Supply Active PFC 140MM Fan ~ $121.99
http://ncix.com/products/index.php?sku=35294&vpn=PVT36G1600LLK&manufacture=Patriot -Patriot Extreme Viper PVT36G1600LLK 6GB DDR3 3X2GB DDR3-1600 CL 8-8-8-24 Triple Channel Memory Kit ~ $139.38
http://ncix.com/products/?sku=37232&vpn=ST31000528AS&manufacture=Seagate -Seagate Barracuda 7200.12 1TB SATA2 3.5IN 8.5MS 7200RPM 32MB Hard Drive OEM *3YR MFR Warranty* ~ $112.07
http://ncix.com/products/?sku=38115&vpn=SH-S223F/BEBE&manufacture=Samsung -Samsung SH-S223F Black 22X DVD Writer SATA OEM ~ $31.08
So how's my build? The total is $1,207.77 and I will get like 10%-15% discount. I have a 17 inch sony screen, speakers, mouse and keyboards, so I won't be needing those things!
my friends dad said its fine with dd2 ram
Your friends dad is a dumbass then, you need an lga1366 X58 motherboard and triple channel ddr3 memory, with a voltage no more than 1.65volts to run a core i7. The nehalem cpu has an on die ddr3 memory controller, and will work for ddr3 memory only.
ASUS P5Q Pro ATX LGA775 P45 DDR2 2PCI-E16 CrossFire 3PCI-E1 2PCI SATA2 Sound GBLAN eSATA Motherboard ~ $159.36
[/QUOTE]
I know but you don't tell someone what to buy if you don't know if they're completable ;)
EDIT: Dang my B-day is Aug 16 :( I'm not a year older
